03-16-2020 06:37
03-16-2020 06:37
My Fitbit Inspire screen is black, the backlight doesn't work. The device is on (92%) battery but nothing on the screen. The device was purchased in January 2020.
03-16-2020 07:39
03-16-2020 07:39
Hi, @Sunshine2790 , have you tried giving your Inspire a restart? That’s usually the solution. Instructions:
The most usual reason for this not working is not holding the button long enough (sometimes 5 secs is not long enough, so please try up to 30 seconds, or repeat the procedure. Also make sure that there is good contact with the pins, as, by design, it will only restart if it is actually plugged in and charging
Th
