03-10-2021 20:20
03-10-2021 20:20
Greetings. Fitbit app on iPad suddenly stoped openning Inspire HR to setup/change silent alarm. The app just shut down after I click on Inspire HR. I restarted the device several times. Didn’t help.Thank you.
03:24
09:00
03-11-2021
03:24
09:00
@Tatyanass Thanks for joining us!
Thank you for troubleshooting this issue. I suggest you log out from the app, restart your iPad and log back in. Also make sure that the app is up to date.
Hope this helps.
Best Answer03-11-2021 05:07
03-11-2021 05:07
@AlvaroFitbit Thanks a lot for the advice. Didn’t help.. 😞
Best Answer03-11-2021 05:56
03-11-2021 05:56
Greetings. I deleted the app and installed it again. The issue resolved.
03-11-2021 09:21
03-11-2021 09:21
@Tatyanass glad to hear that the issue was resolved and thank you for sharing what you did to fix it as it may help other members in the same situation.
Happy stepping and stay safe.
