09-11-2019 04:55
09-11-2019 04:55
When using intervall training in my Inspire HR and setting the movement and rest timings via fitbit homepage, the fitbit android app registers the movement as rest, and rest as movement.
The Inspire HR is timing my intervall correctly as set up on the fitbit hompage.
A software bug?
09-12-2019
09:33
11:39
09-12-2019
09:33
11:39
@SwedeErik Welcome! It's great to see you around!
Let me help you with your interval activities. Try restarting your device following these instructions. After this remove the interval training settings or change it to something different. Save and sync your device then return them to the desired settings, save and sync again.
Let me know how it goes.
10-03-2019 04:54
10-03-2019 04:54
Hi Alvaro!
I tried the solution you gave me, but sadly without good results.
The Fitbit app still saves my data the wrong way around.
Movement as Rest and Rest as Movement.
Is the only way around this to set my preferd intervall times the wrong way around?
Thanks!
/Erik
05-21-2020 04:21
05-21-2020 04:21
It's the same for me. Fitbit HR shows the right setting, but afterward, in the app, it's the opposite way. I guess either the app shows it wrong when you set up the training, and the Fitbit shows it wrong, or it synchronizes badly. Or it's just the app having the wrong words programmed.
