06-29-2022 17:05 - last edited on 12-18-2022 22:19 by MatthewFitbit
My inspire two shows all the data on the screen and indicates it’s syncing
but no data appears on my iPhone
06-29-2022 18:44
06-29-2022 18:44
Hello @Cheznirth
Check to make sure your Fitbit App has the latest update. Then try logging out of the Fitbit App, force shut the app by swiping it upward. Now turn off your phone for about 1-2 mins then turn your phone back on and try logging back into your Fitbit App as usual with email address and password. Now sync your Inspire 2 and see if that resolved the issue. If the problem persist try uninstalling the Fitbit App and reinstalling again to see if that helps.
😃 I hope this helps and gives you the answer you need. Please let me know and keep me posted on how it goes
06-29-2022 18:44
06-29-2022 18:44
Hello @Cheznirth
06-29-2022 19:24
06-29-2022 19:24
06-29-2022 19:31
06-29-2022 19:31
That’s awesome @Cheznirth! 😃 I’m happy it worked out! Enjoy the rest of your evening and as always Happy Stepping!
