05-27-2019
22:37
06:25
YojanaFitbit
05-27-2019
22:37
06:25
YojanaFitbit
My Fitbit inspire HR won’t turn on and it’s been plugged into the charger for a long time it just keeps vibrating randomly what should I do??
Best Answer05-28-2019 06:24
05-28-2019 06:24
How you doing @Jessicabrewster? Thanks for joining this family, hope you like what find here!
Thanks a million for reaching out to report the issues with your Fitbit Inspire. This is not a normal behavior, I'll be glad to give you a hand with this. I'd suggest to restart your Inspire HR. Then give it a try for another day and if you notice this is acting erratically again, please let me know so I can request a ticket for you.
I'll be around!
Best Answer05-28-2019 14:55
05-28-2019 14:55
Best Answer05-29-2019 13:14
05-29-2019 13:14
Thanks for trying the suggested steps, sorry that it didn't help @Jessicabrewster! I've requested to our Support team to create a case on your behalf. You should soon receive an email from Customer Support at the email you used to register with the Community forums.
I'll around in case that you need anything else! ![]()
Best Answer05-29-2019 21:44
05-29-2019 21:44
Best Answer05-31-2019 12:20
05-31-2019 12:20
Hey @Jessicabrewster nice to see you again. My apologies for the delay. Did you check your email inbox? Our team will let you know your case number and the steps that you have to follow from now on to get you back on track.
Let me know if you have questions about this.
Best Answer08-15-2019 10:33
08-15-2019 10:33
Best Answer08-15-2019 23:02
08-15-2019 23:02
My Inspire HP is doing the same thing. Every now and then I see a smile face but nothing is happening- even the green light on the back in not on. It won't charge either. Please help.
Best Answer04-27-2020 15:21
04-27-2020 15:21
mine is doing the exact same, did you find out how to fix it
