09-27-2020
20:51
04:12
JuanJoFitbit
09-27-2020
20:51
04:12
JuanJoFitbit
It won't charge! It suddenly went dead and the battery was not empty. I can't do soft or hard resets because it won't turn on. I've tried multiple chargers and outlets. It's less than a year old.
09-29-2020 11:03
09-29-2020 11:03
Hey Kevin, I'm having the exact same issues you are. I called their help number and they're setting me up with a replacement through the warranty pretty easily!
Best Answer09-28-2020 04:12
09-28-2020 04:12
@Kevin800, welcome to our Fitbit Community! I'm sorry to hear that your Fitbit Inspire is not turning on or taking a charge. By the way, thank you for trying to get this issue resolved before contacting our forums.
I would like to know if your Fitbit Inspire vibrates when you put it on the charger. In the meantime, try the troubleshooting steps that are listed in this help article. This article contains steps that you already tried but you can skip them and proceed with the rest. After this, charge your Fitbit Inspire for 2-3 hours and see if the issue gets fixed.
Keep me posted on the outcome.
Best Answer09-28-2020 05:13
09-28-2020 05:13
Hello! I have tried all of the applicable suggestions from this article and none of them work. The Fitbit is still unresponsive. Thanks for your help.
09-28-2020 11:07
09-28-2020 11:07
And it doesn't vibrate or respond at all when I plug it in to charge.
Best Answer09-29-2020 06:07
09-29-2020 06:07
Do you have any other suggestions? How do I get it replaced since it's under warranty?
Best Answer09-29-2020 09:49
09-29-2020 09:49
So what do I do now? How do I get it replaced?
Best Answer09-29-2020 11:03
09-29-2020 11:03
Best Answer10-01-2020 13:28
10-01-2020 13:28
What's the number? I couldn't find one!
Best Answer10-01-2020 13:42
10-01-2020 13:42
(877) 623-4997
Best Answer10-01-2020 13:54
10-01-2020 13:54
I found the number, thanks!
