Fitbit not recording my sleep cycles
Hi my Fitbit has stopped recording my sleep cycles gave I switched something off
6 REPLIES 6
@Diggsben , A warm welcome to the Community! Thank you for your message.
What Fitbit are you using?
Are the green LEDs blinking?
Do you see the the simplified sleep record or none at all?
I have an Inspire2. No longer has flashing green. Records nothing. No records
Seems like on my inspire2 the sleep setting was off thanks seems to be working now
Sent from my iPhone
My Fitbit HR is doing the same thing. How do we fix it?
My Fitbit HR has flashing green light and does the simplified version of sleep but no longer does cycles. Do I manually have to log in sleep time every night? I never had to do that before
@Diggsben , Thank you for your reply ! i'm glad that the settings were causing this and could be solved.
@Tazzdevil , A warm welcome to the Community! Thank you for your information.
Please hold both buttons of the Inspire 2 to see the quick settings.
Make sure that the tracker is on wrist mode and not on clip .
Also verify on the Settings App on the Inspire 2 > Heart rate. that it is on.
@Funnyone , A warm welcome to the Community ! Thank you for your information.
The following conditions can prevent the recording of sleep stages:
- You record your sleep using the app instead of the tracker's automatic sleep detection.
- The tracker's battery is almost empty when you go to bed (below 25%). This prevents a regular recording of the heart rate.
- You use the metal bracelet while sleeping
- You sleep less than 3 hours.
- The bracelet is too loose or too tight on the wrist. You should be able to put your index finger between the bracelet and your arm without much resistance, so that your heart rate is recorded regularly and the sleep phases can be recognized.
If you tap the recording that doesn't show you any sleep stages, you should get a message explaining why you didn't get any. What is this message?
