03-29-2020 19:39
03-29-2020 19:39
Ok, so I want to know if anyone's having the same problem and also if you turn the hr thing off will the calories burned be lower because I'm cutting 500 calories a day but on a good day I'm reaching for them still... thank you. 😄 Also, I'd like to add that I already made sure my heart rate zones were normal and I put the option to my dominant hand.
Best Answer03-29-2020 21:12
03-29-2020 21:12
Can you explain more why you think Fitbit is overestimating your calories burned?
You said " I'm cutting 500 calories a day but on a good day I'm reaching for them still". I don't understand what that means.
Best Answer03-30-2020 08:42
03-30-2020 08:42
Best Answer03-30-2020 08:43
03-30-2020 08:43
I mean that on a good day when I’m not super hungry it’s hard for me to reach those calories that are set for me to lose a pound a week and that’s not usually the case with other programs such as myfitness pal and I just think it’s an overestimate so I turned off my hr option to see if it’s any more accurate.
Best Answer03-30-2020 08:46
03-30-2020 08:46
Whoops, sorry double message.
