Fitbit recording driving as steps
I drive a school bus all day the fitbit is tracking driving as steps. Its tracking about 6000 steps a day when I am behind the wheel? Is there anyway to fix this?
2 REPLIES 2
You can remove the steps manually, but since you're driving at least twice a day all week, that might be a bit much for you to do. Have you considered using the clip option for the Inspire 2 to see if that makes a difference? You could also put it in a pocket to see if that reduces the number of driving steps.
Stepping in the U.S.A. since September 2013. Android 14
I'll try that. Thank you!
