09-06-2019 19:05 - edited 09-06-2019 20:26
I've read a whole bunch of posts about these issues, and i'm struggling to get any suggestions to work.
I'm on a Samsung galaxy S7.
First it stopped syncing, and when I manually tried to sync it gave me a pink/red circle with an exclamation point in it. Then it booted me out of the app, and when I try to log on it says "Fitbit.com is unavailable. try again later" or "No internet connection". I tried to fix it by turning off bluetooth and it unpaired it, and will not pair again.
Things I've tried:
What else can I do? I've only had the device for just over a week, maybe two weeks. I've seen so many posts with similar issues and I'm feeling disheartened.
Best Answer09-06-2019 19:07 - edited 09-06-2019 19:08
same issue...got message saying website unavailable try later...had another message that said down for maintenance...
Best Answer09-06-2019 19:41
09-06-2019 19:41
Okay, so is that fitbit's maintenance message then?
Best Answer09-06-2019 19:44
09-06-2019 19:44
Same, except I’m on an iPhone. I’ve had so many issues the last few weeks I think I need to get a different tracking device
Best Answer09-06-2019 19:55
09-06-2019 19:55
Me to, I talked to tech support and they just said keep trying....grrrr
Best Answer09-06-2019 20:24
09-06-2019 20:24
It just started for, trying all the suggested steps and nothing.
The stupid thing is if I intentionally put an incorrect password in, it returns with a bad user/password message. If I put the correct password i get the fitbit.com is unavailable message.
So it is obviously connecting far enough to check login credentials
Best Answer09-06-2019 20:29
09-06-2019 20:29
I could have written this post except I just got my fitbit two days ago. Please help with this issue.
Best Answer09-06-2019 21:03
09-06-2019 21:03
mine has just started working agin
