Floral watch band
I lost the small piece that holds the watch band down
3 REPLIES 3
Hello @Laugra5
I wasn’t completely sure if you mean the small pin that’s on the end of your band that holds it to your Inspire 2 which you can find that replacement part here: https://www.amazon.com/FitTurn-Release-Compatible-Inspire-Replacement/dp/B09MW28PNF/ref=pd_lpo_3?pd_...
Or you looking for the fastener ring that holds down the excess band down which you can find here as a replacement: https://www.amazon.com/Fastener-Compatible-Silicone-Replacement-Retainer/dp/B08Q827JZN/ref=pd_lpo_1?...
But you can purchase another complete Floral replacement band here which economically is a much better deal: https://www.amazon.com/REYUIK-Compatible-Replacement-Accessories-Wristband/dp/B07XKGX6H6?th=1
😃 Please let me know if this provides you with the best answer
Thank you very much for the info. Already ordered.
😃 That’s fantastic news @Laugra5! I’m happy it helped
