Font size on Fitbit inspire hr
I have found that when you use the exercise mode on the Inspire HR it does display heart rate and other parameter in a much larger font than the normal clock face screens. It could still be larger and adding in the exercise shortcuts is another topic in itself, but I’m 66 and I can see the heart rate in the midst of even vigorous workouts when in exercise modes.
2 REPLIES 2
@BenJoe, a warm welcome to our Community!
Thank you for your suggestions. If you wish you can share your suggestion in our Feature suggestions board. Search for the idea first to see if one already exist so you can add your vote. The more votes an idea gets the more likely the developers will try to implement it.
Let me know how it goes.
Alvaro | Community Moderator
There was a post about font size that I wanted to reply to but I could not see a way to do it so I posted it as a “new topic.” I think there is a post that it has already been entered as a feature request. I have to admit it seems like that should be a pretty easy fix since there are already several clock faces available.
Sent from my iPhone
