06-01-2020
21:18
09:30
AlvaroFitbit
06-01-2020
21:18
09:30
AlvaroFitbit
Hi there,
My Inspire HR Was working perfectly until I updated to the latest version of the app on iPhone X iOS 13.4. Since the update, I’m having two main issues:
1) Fitbit won’t sync unless I completely close the app (not just exit but swipe app on the list of open apps), it says “Failed to Sync” unless I do this.
2) My cardio (runs and walks) suddenly started showing as straight lines on the map. The rest of the data seems correct (distance etc) but it just shows as if I went from point A to point B in a straight line, which is not the case
06-07-2020
09:33
06:58
06-07-2020
09:33
06:58
@Beholder69 Welcome to the Fitbit Community! It's great to have you here!
Let me help you with your Inspire not syncing and your GPS maps being incorrect. You can try the following:
Let me know how it goes.
06-07-2020 11:49
06-07-2020 11:49
Thanks, Alvaro!
Restarting both devices seems to have fixed the sync issue.
As for the GPS, I found some advice in another thread saying to lock the phone while you have the app open (nice workaround but shouldn’t have to do this to get it to work) and my last 2 runs we’re showing properly.
Not sure if it was the workaround that did the trick or the restarting, next time I’ll try running with the app on the background instead of open and see what if it has been fixed and then update. Thanks again!
