11-30-2021 07:00
11-30-2021 07:00
Just wondering if others have had as many problems with their Fitbit as I have had. I own two, one is mine and one is my daughters and neither have ever functioned consistently or reliably. I spend more time re-starting, updating, un-installing, re-installing, and troubleshooting than I do using the device. Even tracking steps isn’t accurate. I honestly don’t even want a replacement because I have no confidence in the product. If anyone else is dealing with the same issues, you are not alone.
Best Answer12-03-2021 04:52
12-03-2021 04:52
Yes, I'm having the very same problems and I'm tired of spending so much time trying to fix it!
12-16-2021 08:45
12-16-2021 08:45
My InspireHR died completely after being charged & is out of warranty! I called support to no avail— they sent a 35% off coupon which is useless! 👎😢 Everytime I added a product to my basket it would come back that the coupon couldn’t be used!! There was not one product the coupon was good for! A call to Support was useless with no reason why! I am disgusted with poor Customer Support! Prices on their website are the same at Amazon, Best Buy, Walmart, Target etc How was giving a useless coupon good customer support?!!!
12-19-2021 19:51
12-19-2021 19:51
Wonder if they even read these complaints
12-20-2021 02:35
12-20-2021 02:35
Have you gone into your settings? I think you can change how the Fitbit determines your active minutes. I haven’t played around with those settings, as I don’t personally track my active minutes.
Best Answer12-20-2021 02:37
12-20-2021 02:37
I’ve had mine for almost two years, and I haven’t had any issues, other than I can tell my battery is going. It has to be charged more often now—probably every 3-4 days.
Best Answer12-20-2021 11:50
12-20-2021 11:50
I am having similar issues. Mine will be 2 yrs old in March and I am currently needing to charge a couple times a week, especially when I am more active. It used to last at least a week. Hoping the 'ole girl will live for at least another 3-6 months so I can plan for buying something new. 🙂
Best Answer12-20-2021 15:13
12-20-2021 15:13
Best Answer12-23-2021 14:17
12-23-2021 14:17
I had a great fitbit before but this one is a piece of crap. The steps, active minutes everything is constantly wrong. I never had issues before with my Fitbit HR. when it started burning my wrist I contacted them to get anew one. I expected to purchase it as mine was 2 years old. They insisted i return it and then it took two months to get a response and then they sent this piece of crap to me. I really want what I had but they don't make it anymore and now I know why this one was free..... Can someone one tell me what is the closest replacement to the original Fitbit HR???
Best Answer01-01-2022 11:41
01-01-2022 11:41
Battery started to get down to 3 days on my Charge 3 - so I "upgraded" to Inspire 2 Same thing is already happening in the Inspire. I have trouble figuring out how to change settings... For 3 months now this thing (Inspire 2) has never been able to track my sleep. Time for a better product... looking into another brand.
01-02-2022 15:34
01-02-2022 15:34
no I dont think I have gone through 2 inspires and now a versa 3 going to check out another fitness tracker tired of spending a lot of money for something that works less than a year
