Globe icon
ANSWERED
I received a notification that shows a globe icon with a number underneath it. I looked in the manual and could not find this. It flashes on and then seems to disappear.
1 BEST ANSWER
Accepted Solutions
@dmmarlowe the default goal for Active Zone Minutes is 150 per week. If you have that notification enabled, you will see alerts at 150 AZM and at multiples of that value, including at 300 AZM.
Community Council Member
Amanda | Wyoming, USA
Pixel Watch 4, Inspire 3, Sense | Android
11 REPLIES 11
@dmmarlowe does it look something like this?
 That's the notification to show that you've reached your step goal.
Yes…but the number below shows 300 and I don’t believe there are footprints on the icon. My step goal is 10,000 and this showed up way past 10,000 steps (I average in the 20 thousands
@dmmarlowe in that case, it may be notifying you that you have reached your Active Zone Minutes goal. I haven't used an Inspire 2 in a while, but I seen to remember that there is a notification for that as well.
I appreciate your suggestions, but the preset active zone minutes on the Inspire 2 are 22 minutes and this is 300
On my Inspire 2 I will see Active Zone Minutes alerts every 150 active zone minutes. So when this occurs during the week, I will see 150 when I reach 150 active zone minutes for the week, then 300, then 450, 600, 750, etc depending upon when I reach these totals during the week. This setting is under Activity & wellness -- Daily Activity -- then under Weekly Activity -- Active Zone Minutes. My setting is at 150. Hope this helps
Thank you! I believe this is the answer I’m looking for.
Do do you know if I can change the auto recognized exercises? I would want to change the elliptical to an exercise bike.
@dmmarlowe unfortunately, there isn't a way to do that. Your Fitbit is not able to auto recognize stationary cycling. It recognizes activities based on the motions of your arms, so it can't "see" that you're using a stationary bike.
Of course, that makes sense. Thank you.
