11-15-2022
15:36
21:01
11-15-2022
15:36
21:01
I received a notification that shows a globe icon with a number underneath it. I looked in the manual and could not find this. It flashes on and then seems to disappear.
11-16-2022 15:20
11-16-2022 15:20
@dmmarlowe the default goal for Active Zone Minutes is 150 per week. If you have that notification enabled, you will see alerts at 150 AZM and at multiples of that value, including at 300 AZM.
Amanda | Wyoming, USA
Pixel Watch 3, Inspire 3, Sense | Android
11-15-2022 21:17
11-15-2022 21:17
@dmmarlowe does it look something like this?
That's the notification to show that you've reached your step goal.
11-15-2022 23:52 - edited 11-15-2022 23:54
Yes…but the number below shows 300 and I don’t believe there are footprints on the icon. My step goal is 10,000 and this showed up way past 10,000 steps (I average in the 20 thousands
11-16-2022 06:27
11-16-2022 06:27
@dmmarlowe in that case, it may be notifying you that you have reached your Active Zone Minutes goal. I haven't used an Inspire 2 in a while, but I seen to remember that there is a notification for that as well.
11-16-2022 08:26
11-16-2022 08:26
I appreciate your suggestions, but the preset active zone minutes on the Inspire 2 are 22 minutes and this is 300
11-16-2022 12:27
11-16-2022 12:27
On my Inspire 2 I will see Active Zone Minutes alerts every 150 active zone minutes. So when this occurs during the week, I will see 150 when I reach 150 active zone minutes for the week, then 300, then 450, 600, 750, etc depending upon when I reach these totals during the week. This setting is under Activity & wellness -- Daily Activity -- then under Weekly Activity -- Active Zone Minutes. My setting is at 150. Hope this helps
11-16-2022 15:20
11-16-2022 15:20
11-16-2022 16:35
11-16-2022 16:35
Thank you! I believe this is the answer I’m looking for.
11-16-2022 16:35
11-16-2022 16:35
11-16-2022 16:39
11-16-2022 16:39
Do do you know if I can change the auto recognized exercises? I would want to change the elliptical to an exercise bike.
11-17-2022 07:49
11-17-2022 07:49
@dmmarlowe unfortunately, there isn't a way to do that. Your Fitbit is not able to auto recognize stationary cycling. It recognizes activities based on the motions of your arms, so it can't "see" that you're using a stationary bike.
11-17-2022 08:09
11-17-2022 08:09
Of course, that makes sense. Thank you.
