03-26-2019
12:31
09:40
LuciaFitbit
03-26-2019
12:31
09:40
LuciaFitbit
Hi. Just got my fitbit inspire hr today. It's the first time I have used a Fitbit. However the heart rate is not working. The green light is flashing on the watch and heart rate is switched to on also. Have tried resetting but this hasn't worked. Can anyone help please ?
Moderator edit: Title
Best Answer04-05-2019 12:12
04-05-2019 12:12
I ended up returning mine as faulty and getting the new one, it seems working for the last couple of days straight out of the box.
Best Answer04-05-2019 15:23
04-05-2019 15:23
I did the same. Returned it and have had no problems with the new one.
Best Answer04-09-2019 13:16
04-09-2019 13:16
Best Answer04-20-2019 16:35
04-20-2019 16:35
I just had the same problem and after a day I finally figured it out. The instructions are not clear. I don't know how many times I went into the dashboard trying to figure out where to turn the **ahem** heart rate on. Its because you have to turn it on the through the actual device, NOT the fitbit app. I must have accidentally turned it off or one of my kids messed with it. So to turn it on, scroll up from your clock display until it says "settings", then click the settings icon and it comes up right there, plain as day, HEART RATE...tap it to turn the selection to "ON" and hopefully that will fix it for you!
04-22-2019 21:43
04-22-2019 21:43
Hey, thanks a lot! This solved my problem. No idea how I managed to turn that off.
04-23-2019 02:00
04-23-2019 02:00
I ended up exchanging my device at Currys - the new one has worked perfectly so far with no issues. It must have been a faulty unit.
Best Answer04-23-2019 08:43
04-23-2019 08:43
Perfect! Glad it worked!
Best Answer05-02-2019 05:45
05-02-2019 05:45
I've gone to all the settings online and on the app and cannot find where to see if the HR is turned on. All I know is that it is not tracking. I just received my Inspire HR yesterday.
Best Answer05-02-2019 08:18
05-02-2019 08:18
I did that too, but the setting is on the device, not on the dashboard. Scroll up a little here, or go right to this post. That worked for me.
05-02-2019 09:06
05-02-2019 09:06
Best Answer05-02-2019 10:55
05-02-2019 10:55
You're welcome! Well done!
Best Answer05-19-2019 13:57
05-19-2019 13:57
Thanks - exactly what the problem was. Would help if Fitbit wrote this on their instructions rather than the useless instructions that leave you scratching your head for non-existent settings on the app
Best Answer05-20-2019 22:35
05-20-2019 22:35
My inspire hr still does not work properly with the heart rate. It never worked to begin with. I have installed with my Surface 2 laptop windows 10 and my cell phone which is a LG Thinq
Best Answer05-23-2019 04:15
05-23-2019 04:15
Thank you! This is v helpful! I spent a day trying to find the ‘On’ button on my app...without realizing the setting is on my Fitbit!!
Best Answer05-23-2019 08:32
05-23-2019 08:32
06-03-2019 21:38
06-03-2019 21:38
Thank you, Mermaid! That worked.
Best Answer06-03-2019 21:40
06-03-2019 21:40
Same thing occurred to me...
Best Answer06-09-2019 13:35
06-09-2019 13:35
I had the same problem, the solution worked for me, thank you!
Best Answer06-24-2019 15:37
06-24-2019 15:37
Same problem - works now - thanks! ![]()
Best Answer06-29-2019 00:24
06-29-2019 00:24
Cannot thank you enough for this! The instructions are far from this and I was about to make a trip to the store. Thank heavens for you!
