03-26-2019
12:31
09:40
LuciaFitbit
03-26-2019
12:31
09:40
LuciaFitbit
Hi. Just got my fitbit inspire hr today. It's the first time I have used a Fitbit. However the heart rate is not working. The green light is flashing on the watch and heart rate is switched to on also. Have tried resetting but this hasn't worked. Can anyone help please ?
Moderator edit: Title
Best Answer07-08-2019 19:12
07-08-2019 19:12
thankyou!!!!! it was easy!
Best Answer07-20-2019 14:41
07-20-2019 14:41
This was the most helpful post!! Thank you so much for sharing!! 😊
Best Answer07-23-2019 21:41
07-23-2019 21:41
Thanks sooooooo much. So simple a fix 🙂
Best Answer08-08-2019 13:29
08-08-2019 13:29
My Inspire HR is like this too. It's new today as my previous charge 2 broke.
Did you find a fix?
Best Answer08-08-2019 16:56
08-08-2019 16:56
08-20-2019 23:37
08-20-2019 23:37
Same here. Omg. Known issue?
Best Answer08-21-2019 14:07
08-21-2019 14:07
Thank you! I went to p as he 40 as suggested, followed the steps and it worked. Somehow the HR was turned off.
Best Answer09-05-2019 20:26
09-05-2019 20:26
Thank you! Fitbit needs to give better instructions. You are a lifesaver!
09-06-2019 19:17
09-06-2019 19:17
HR worked on mine for two days. Have tried to reset but nothing is working. HR is the main reason I bought this fitbit. Can anyone assist with this?
thanks!
Best Answer09-07-2019 00:26
09-07-2019 00:26
09-07-2019 10:14
09-07-2019 10:14
Best Answer09-08-2019 08:19
09-08-2019 08:19
I do not see any option for Heart Rate when I go onto settings.
Best Answer10-09-2019 03:28
10-09-2019 03:28
Thank you for sharing that. I read page 40 of the manual and mine is now working. It was switched off in settings. I have spent a long time trying to get it working and was getting very frustrated 😊
Best Answer11-16-2019 06:30
11-16-2019 06:30
I don’t see heart rate anywhere in the settings. Can someone say where it is step by step for the inspire hr?
Best Answer11-19-2019 18:09
11-19-2019 18:09
I had the same problem. Now got solved it.
Tap on the Fitbit Screen > you will see the Time an Date
Scroll down till you reach SETTINGS
Tap on SETTING
You can see first PHONE GPS
Scroll up then you can see HEART RATE - switch this on
Best Answer11-26-2019 07:17
11-26-2019 07:17
I see your comment was 2 months ago - here's one thought - there's 2 flavors of these, "Inspire HR" and "Inspire". The "HR" means, heartrate - the "Inspire" model is a bit cheaper & does not have heartbeat ability. Could yours been just an "Inspire"?
Best Answer12-08-2019 15:37
12-08-2019 15:37
Thank you, I was able to fix the heart rate tracking by changing the settings on the device itself!
Best Answer01-05-2020 03:43
01-05-2020 03:43
Is it normal that I cannot even find the setting app? Nothing is where you say it is. This is so disappointing! heartbeat stopped after a week or my purchase.
Best Answer01-05-2020 12:44
01-05-2020 12:44
The heartbeat setting cannot be fixed from the app. You must click the button on your Fitbit once. Swipe DOWN on the screen 5 times to get to the “Setting” screen. Tap “Setting”. Swipe UP once to get to “Heart rate”. Tap “Off” to change it to “On”. Now it will be fixed!
Best Answer01-05-2020 13:19 - last edited on 03-29-2020 18:57 by LiliyaFitbit
well, it finally did just start working - but what HAS stopped is the text
and phone notifications ... please stop me if I ever say I'll buy this
again.
