Heart rate spiking while idle - Inspire 2
This is my second full day using the Fitbit Inspire 2... Yesterday I had to restart the device at least 3 times because heart rate would register 120 - 140 while sitting at my desk. Once I restart the device the heart rate registers my normal heart rate in the 70 - 75 bpm range.
Today the same thing started to happen so I logged on here and found this:
  • Switch the Heart Rate settings from On to Off and manually sync your Inspire 2. To switch the heart rate settings on your Inspire 2, from the main screen of your Fitbit device, swipe left until you see "Settings", next swipe up until you see "Heart Rate" and switch it to Off.
  • Once it's done, manually sync your Fitbit device. To do so, open the Fitbit app, tap on the Account icon, tap on your Inspire 2's image and tap on "Sync Now"
  • Next, switch it from Off to On and manually sync your Inspire 2 once again.
  • Once it's done, restart your Inspire 2 once again. To do so, press and hold the left button for 8 seconds while it is plugged into the charging cable as if it were charging.
  • Next, confirm that your tracker is snug on your wrist (the lights shouldn't be visible) We also recommend when you're not exercising, wear the tracker just above the wrist bone.
Not long after I tried this I caught my bpm around 115... I restarted again and back down to the 70s range.
Anything else I should try?
0 REPLIES 0
