03-13-2019
18:29
14:23
AndreaFitbit
03-13-2019
18:29
14:23
AndreaFitbit
My heart rate monitor stopped. The green LED stopped blinking on my Inspire HR.
Resetting did not work.
Disconnect / removed from the app / profile did nothing.
I ended up erasing all personal data from it and then it worked.
Best Answer08-20-2019 07:23
08-20-2019 07:23
Best Answer08-24-2019 10:31
08-24-2019 10:31
I had this issue and resolved it quickly. I went into the Fitbit, swiped to get to settings, then turned on the HR option. It seems to have reset that option from the update.
Best Answer09-12-2019 21:25
09-12-2019 21:25
I have the same issue but erasing my data and restoring it back did not work, I have did everything and nothing makes it work
Best Answer09-25-2019 11:14
09-25-2019 11:14
This worked awesome for me. It was quick and no issues at all.
Thanks
Best Answer10-07-2019 12:27
10-07-2019 12:27
I just had the same experience with my Versa. It worked for my run Sat morn and Sat afternoon no heart rate. I can't get it to work. I've only had the device since Feb.
10-23-2019 16:55
10-23-2019 16:55
I went to try this and the settings app is no longer on my device. The phone app says it’s installed, but it’s not on the Versa. ???
Best Answer01-08-2020 17:39
01-08-2020 17:39
Hi! I'm desperate... I've tried everything I've read in this forum and nothing worked : I made sure the heart rate was on in the settings on my device, cleared user data, reset my device, and deleting my device in the Fitbit app. None of this worked. Please help!
01-08-2020 17:53
01-08-2020 17:53
Hello folkgirl,
I am not sure there is a fix if it’s not under warranty. I myself decided to go ahead and get the Apple Watch being as I have an iPhone, I am glad that I did now because on the Fitbit I could see my text messages but with the Iwatch I am able to reply to email reply to text messages and even since I have a XS Max phone with iOS 13 I am able to use my watch as a phone if it’s close by. The only issue I hate is that I have to charge the Apple Watch about once a day if I use it very much.
Timothy
Best Answer01-08-2020 17:58
01-08-2020 17:58
I called customer service and they said they were working on a fix. I got frustrated after 6 months and called again. They sent me a new one. Call and insist. They can see it’s not working. They know it’s a programming problem. Be persistent.
Best Answer01-08-2020 21:53
01-08-2020 21:53
re: You can resolve this by 'Clearing user data' found in the Settings app on the device.
Could you please tell me exactly where to find this option? I'm using an iphone 11, and a macbook.
Best Answer01-09-2020 01:02
01-09-2020 01:02
I have the same problems:
heart rate lights not working
i have tried all of the following with no success:
1. cleared personal data
2. turned off and on multiple times
3. checked settings on tracker, heart rate on. Even turned off then on multiple times.
4. Removed tracker from app and reinstalled as new device
5. turned Bluetooth on and off multiple times.
01-09-2020 07:12 - edited 01-09-2020 07:13
Mine finally started working again, after doing all the things you mentioned, Calinate. Removed everything, re-installed, re-connected, etc. I also rubbed the contacts with my cotton shirt, made sure my 3 devices were sitting together, and performed some magic spells 🙂 Then I gave up, and a little while later I noticed it was tracking. I don't know why!
Best Answer01-09-2020 07:15
01-09-2020 07:15
Best Answer01-09-2020 13:50
01-09-2020 13:50
Best Answer01-09-2020 17:11
01-09-2020 17:11
Best Answer01-10-2020 15:31
01-10-2020 15:31
Best Answer01-10-2020 15:40
01-10-2020 15:40
Best Answer01-10-2020 17:27
01-10-2020 17:27
Yup there's no reason a customer should have to put up with that.
Best Answer01-21-2020 11:13
01-21-2020 11:13
I factory reset my Fitbit versa and it still doesn’t track my heart rate or sleep
Best Answer01-21-2020 12:41
01-21-2020 12:41
