03-13-2019
18:29
14:23
AndreaFitbit
03-13-2019
18:29
14:23
AndreaFitbit
My heart rate monitor stopped. The green LED stopped blinking on my Inspire HR.
Resetting did not work.
Disconnect / removed from the app / profile did nothing.
I ended up erasing all personal data from it and then it worked.
Best Answer04-03-2020 12:47
04-03-2020 12:47
Thank you. You and your family as well.
Best Answer04-03-2020 16:16
04-03-2020 16:16
Thanks everyone who suggested calling Fitbit’s Customer Service for help on trying to get the Heart Rate monitor on my Fitbit to start working again. After trying every known way to fix my problem (which I already did before), none of which worked, she emailed me the link to get a replacement.
Best Answer04-08-2020 14:40
04-08-2020 14:40
Hi , my Fitbit versa heart rate suddenly stopped working and the green LED also ... I restarted alot , i also shut down the heart rate monitor from the watch and turned it on again.. ? WHat shall i do
04-08-2020 14:50
04-08-2020 14:50
Best Answer04-08-2020 17:12
04-08-2020 17:12
If it's not still under warranty, I would switch to Apple, only thing is that you need Apple phone also, but the new versa might be Ok , at least for a year or so, they are having this same issue with this versa, that I agree with Lisarunner, they should have to give customers a new one.
Hope everyone is safe from the coronavirus!
Tim
Best Answer04-11-2020 14:00
04-11-2020 14:00
Hi, I already performed a clear user data, and a quick restart and it doesnt work, i have done everything I have seen on these forums and nothing works, I have already contacted customer service and they keep sending me articles of what should I do, but i have already made all of them
Best Answer04-16-2020 06:59
04-16-2020 06:59
My heart rate stopped working also. I just added another one and it started working.
Best Answer04-19-2020 07:42 - last edited on 06-18-2020 18:59 by LiliyaFitbit
I tried clearing data on device. Forgetting data device and finding again and turning off my phone and turning back on all to no avail the heart rate will not work. Any other suggestions?
Moderator edit: format
Best Answer04-30-2020 15:38
04-30-2020 15:38
I can’t seem to find the “clear user content” settings. My heart rate monitor just stopped working and I can’t seem to get it back 😞
Best Answer05-28-2020 11:05
05-28-2020 11:05
I have the same issue but the green light is flickering still, i erased user data and it worked but once i sync up again it goes back to not working. Is there a fix for this?
Best Answer06-05-2020 09:12
06-05-2020 09:12
This is the third time IVe did this it’s needs done every 2-3 weeks
can someone please get a proper fix
Best Answer06-06-2020 13:17
06-06-2020 13:17
I’ve tried all of these and it didn’t work. Now with the reset, it’s no longer connecting with the app.
Best Answer06-08-2020 17:44
06-08-2020 17:44
So that is essentially a factory reset right? Doesn't that wipe all of my personal data? Can i recover that?
Best Answer06-10-2020 22:41
06-10-2020 22:41
Mine is doing the same thing. I will try What is suggested
Best Answer06-10-2020 22:42
06-10-2020 22:42
Best Answer06-17-2020 09:40
06-17-2020 09:40
I also have this same issue. Except mine is unresolved, I have done a recharge, restart, reset multiple times and a complete factory reset and still not working. Please help me!
06-17-2020 09:50
06-17-2020 09:50
I have tried all of those as well, still not working.
Best Answer06-17-2020 10:06
06-17-2020 10:06
Hi Matt,
I have tried all the troubleshooting steps listed including a complete factory reset and still my LED lights will not turn back on so heart rate is no longer functioning. Please help!!
Best Answer07-05-2020 11:09
07-05-2020 11:09
I have performed the 15 second reboot and cleared my data and my heart monitor still doesn’t function, no lights are being emitted from the back of the watch.
Best Answer07-05-2020 18:35
07-05-2020 18:35
After calling customer service they had me return my fitbit for a replacement. I am unfortunately still waiting 3 weeks later 😔
