01-06-2020 15:11
01-06-2020 15:11
My resting heart rate through the day is roughly around 72 when I’m sitting on the couch etc. However at night when I’m just about to go to sleep my heart rate goes does to the low 50’s is this a concern as I am not an athlete. I have been to the doctor many times regarding my heart health as it used to be very high but tests have been done and says I’m fine, just wondering if this is common
01-07-2020 07:34
01-07-2020 07:34
@Raecameron Welcome! Thanks for being part of our Community!
Thank you for your inquiry about your low heart rate. This is something I suggest you ask directly to your doctor as they should be able to properly analyze this situation. If you wish you can see if you can get a better reading from your device by cleaning the back of your device with cotton and rubbing alcohol and restart it. Turn the heart rate off, save and sync then turn it on save and sync again. Also check these tips to improve the heart rate reading on your device.
Let me know how it goes.
