10-13-2022 16:36
10-13-2022 16:32
10-13-2022 17:13
10-13-2022 17:13
Hi @KD1999 your posts were merged into one, so you'll get all your responses in one place. I think that is the Inspire - look at the picture of the Inspire here - click to go there. The band is distinctive and the button to push it. See if that looks like it. If so, finding a charger, you'll need to get an authentic one, if possible for the restart button that is on it. Since it's older, Fitbit isn't carrying those chargers in their store. You might find one at a local retailer like Best Buy, Walmart or Target, so you could more easily return it in case it doesn't work.
10-13-2022 17:17
10-13-2022 17:17
thank you. I am in Australia, any idea where I can get it here?
Best Answer10-13-2022 19:15
10-13-2022 19:15
This is a list of authorized retailers - click to go there. Be sure you can return it if it's not the right charger. Without the restart button, it's not worth getting because a restart is usually the first thing to do when you encounter a glitch.
Best Answer10-13-2022 19:17
10-13-2022 19:17
@Odyssey13 , Thank you for your help. I agree with you. This seems to be an Inspire or an Ace 2 without the Child cover. .
@KD1999 , A warm welcome to the Community! Thank you for your messages, pictures and information.
As Odyssey13 mentioned, your Fitbit seems to be an Inspire or Ace 2.
Either way, the charging cable for the Inspire is also compatible with the Inspire HR and Ace 2
Seems that on our Australian there are some available.
Please have a look here
See you around.
