01-23-2020 09:21
01-23-2020 09:21
I have looked everywhere in the manual, and it tells me when the vibration happens, but I want to set it so there are never any vibrations. How do I do that please?
Best Answer01-23-2020 12:18
01-23-2020 12:18
I am not aware of any way to completely stop them, only when they happen. For instance, when you reach your step goal. You can change the goal so it happens at a different time but it will eventually vibrate when you reach the goal unless you set it to an unrealistic number of steps.
Best Answer01-25-2020 08:10
01-25-2020 08:10
Thanks for your reply. I did the trick of setting unrealistic targets, and that was a success. I still get other vibrations at other times, but it looks as if I'm stuck with those. It seems crazy to me that such a clever device can do something so irritating, with no way of stopping it. Oh well - thanks anyway.
