08-28-2020
06:32
06:12
08-28-2020
06:32
06:12
Weight can be a very sensitive and triggering subject for a lot of people. As someone who recovered from an eating disorder, I make a point of not focusing on my weight, but I just got the Fitbit Inspire HR and now I am forced to look at my weight every time I scroll through the watch. There needs to be a way to customize what apps you want on there.
Best Answer08-28-2020 06:42
08-28-2020 06:42
Curious. I scroll through my Inspire HR and don't see weight. Where do you see weight on yours? Can you provide a photo?
Warren | Cincinnati, OH
Versa Lite, Ionic, Charge3, Inspire HR, Blaze(retired), Alta( retired),- Pixel 3
08-28-2020 07:14
08-28-2020 07:14
@wtksk8r It's listed below time with the rest of your stats mine it's the last tile before female health but it might be different for you.
@Lanig11 I'm happy to hear you're recovering and I hope all is well. I don't think you can remove tiles from the fitbit directly you would need to remove the weight tile from your fitbit app completely for it not to show up on your Inspire. It's very unintuitive that you can't customize them separately. (Unless there is a way I cannot find)
08-28-2020 07:27
08-28-2020 07:27
I'm stumped as well. I have the weight tile active on the app but it does not show up on the pebble. I don't see any way to change the tiles on the pebble itself.
08-30-2020 16:26
08-30-2020 16:26
if you remove the widget from the app it will remove from the fitbit
