01-18-2021
06:39
05:10
WilsonFitbit
01-18-2021
06:39
05:10
WilsonFitbit
how do I keep the time on without having to push in the side buttons
Best Answer01-18-2021 10:38
01-18-2021 10:38
@debecho The Inspire 2 doesn't have an Always On Display, however you should be able to view the time by raising your wrist. Make sure Screen Wake hasn't been disabled by holding both sides of Inspire 2 for at least two seconds. If the Screen Wake (lightbulb icon) is greyed out and has a line through it, then you've disabled it. Tap the Screen Wake icon and it should light up and turn white and now when you raise your wrist, you should see your Inspire 2 screen again without having to push the side buttons.
Hope this helps!
01-18-2021 10:38
Hope this helps!
05:09
09:52
02-01-2021
05:09
09:52
Hello @debecho, welcome to the community forums! @Heather-S It's nice to see you around and thanks for your input!
If the response give by @Heather-S helped to resolve your inquiry, I recommend marking the answer given as the best answer. By doing this, other users with the same inquiry will be able to find a faster response.
On a side note, I was informed by the Support Team that you contacted them. Since you have received assistance from them, I suggest you to update your case or get in contact with them one more time if you require further assistance or if you have any additional questions.
Have a great day!
Best Answer06-11-2022 10:31
06-11-2022 10:31
I can’t get the screen wake screen to light up! I can get to the screen wake and it’s dimmed but can’t get it to light back up.
05-23-2023 00:53
05-23-2023 00:53
I managed to work out that you have to first disable sleep mode. Only then can you change the screen wakes settings.
05-23-2023
10:44
09:52
05-23-2023
10:44
09:52
Hi @ChrisTwoCats. It's nice to see you as a new member of the Fitbit Community.
Thanks for the feedback provided to this topic. It will be useful for other users.
Also, I'd like to invite you to visit our Health & Wellness board where you can share your experiences, meet people and create new topics.
