04-26-2019
20:20
09:01
AlejandraFitbit
04-26-2019
20:20
09:01
AlejandraFitbit
How to restart?
Best Answer04-26-2019 20:58
04-26-2019 20:58
How do I restart my Fitbit device?
04-28-2019
09:02
09:31
04-28-2019
09:02
09:31
Welcome to the Forums @SmBc and @JohnnyRow thanks for the input.
I was able to see here that our friend @JohnnyRow replied to your inquiry about how to restart your Fitbit. Was this the answer you were looking for? If it was, I recommend marking the answer given as a solution. By doing this, other users with the same inquiry will be able to find a faster response.
Now, if your inquiry/issue wasn’t resolved, let me know and I will be glad to help you out. 😊
Best Answer07-04-2019 07:06
07-04-2019 07:06
Johnny Row's message had ZERO to do with the question of restart.
How do I restart an Inspire?
07-04-2019 07:19
07-04-2019 07:19
His post is a link to a help file which has the instructions to restart any model of fitbit. In that help file it says for the Inspire:
07-04-2019 07:29
07-04-2019 07:29
@Harney wrote:Johnny Row's message had ZERO to do with the question of restart.
To clarify, on the internet, when you see a line of text in a different color and underlined, and your cursor changes shape when pointed to it, that generally means that is a link, such that clicking on it will take you to another web page, in this case, a page with the answer to your question. Often it makes more sense to refer someone to the official answer, rather than posting the whole thing out again, possibly with errors.
07-12-2019 13:26 - edited 07-12-2019 13:29
To clarify the issue that people see when looking at the response. The link provided does not give the process to restart a fitbit Inspire. It merely says the following:
07-12-2019 13:38
07-12-2019 13:38
@smithkevinj if you then select your type of fitbit from the list on that page you get the specific instructions for that device
08-27-2019 06:19
08-27-2019 06:19
But there’s no link for the Inspire or Inspire HR.
Best Answer08-27-2019 06:28
08-27-2019 06:28
It's under "Ace 2 and Inspire series"
08-27-2019 07:27
08-27-2019 07:27
Oh my word!!! Apparently I'm having challenges reading this morning! Thanks!!!
Best Answer08-27-2019 12:25
08-27-2019 12:25
I tried the restart for the Inspire HR and it does nothing. I'm still stuck with the timer on the screen, it doesn't scroll and won't sync.
08-27-2019 12:32
08-27-2019 12:32
It worked for me. I attached it to the cable. Held the button until there was nothing then pressed the button again until I saw the smiley face.
09-23-2019 11:29
09-23-2019 11:29
how do i restart my inspire hr I tried holding the button and it did not work
Best Answer11-01-2019 03:36
11-01-2019 03:36
My inspire HR was struck on the time screen. Didn't work after pressing the button. Finally I go to the the app and change the clock face. It works! Hope it can help you.
03-08-2020 13:28
03-08-2020 13:28
The smile appeared on my Inspire HR about 2 seconds after releasing the side button. Normal function of the button and screen the returned. p.s. the action that made my screen and button unresponsive was pressing the side button while charging to see if there was a full charge.
Best Answer04-02-2020 12:15
04-02-2020 12:15
Well done for being polite in your reply, when it must have been tempting to be otherwise
Best Answer09-08-2020 13:19
09-08-2020 13:19
Perfect! Yeah, sometimes it takes more than one try to get it to the smiley screen. So annoying when your trying to track what you are in the middle of and the fitbit freezes.
Thanks guys and gals.👍🏽
Best Answer10-03-2020 08:23
10-03-2020 08:23
Which button on Inspire 2 do I press to restart? As I understand it I have two buttons on each site, which one do I need to press?
Best Answer10-03-2020 08:28
10-03-2020 08:28
@Ynavb I think it's both. The manual says:
"If you can’t sync Inspire 2 or you have trouble with tracking your stats or receiving
notifications, restart your tracker from your wrist:
Open the Settings app and tap Reboot Device.
If Inspire 2 is unresponsive:
1. Connect Inspire 2 to the charging cable.
2. Press and hold the buttons on your tracker for 5 seconds. Release the buttons.
When you see a smiley face and Inspire 2 vibrates, the tracker restarted."
