How do I see battery percentage on Inspire screen
ANSWERED
Is there a way to see battery percentage on the inspire screen?
1 BEST ANSWER
Accepted Solutions
Hi @ErinABray Welcome to the forum. Yes, you can see your battery % by holding the button for about 2 seconds, you'll feel a vibration and see the batter % and other options.
Hope that helps!
Marci | Bellevue, WA
3 REPLIES 3
Hope that helps!
Thank you soooo much!!! That helps a ton!
Sent from my iPhone
What is the other option on the battery level screen? Looks like a bulb and it will toggle on and off.
Stephen
