02-12-2022
14:10
22:48
02-12-2022
14:10
22:48
Hi Heather.
How do I stop the water lock from constantly notifying me? It is very annoying and detracts from real notifications. Inspire 2. I just swapped from an Alta hr. Cheers Julianna
Moderator edit: Updated subject for clarity.
02-15-2022 10:32
02-15-2022 10:32
Thanks for getting back to us and for sharing your water lock notifications inquiry @TWNMUM.
To turn off water lock, firmly double-tap the middle of the screen with your finger. If you don't see "Unlocked" appear on screen, try tapping harder. Turning off this feature uses the accelerometer in your device, which takes more force to activate.
Note that water lock turns on automatically when you start a swim in the Exercise app.
I hope this information helps.
