10-17-2020
22:50
18:09
LizzyFitbit
10-17-2020
22:50
18:09
LizzyFitbit
Hey
how about on Fitbit Inpire HR? these steps dont work on the app
thanks
Moderator Edit: Clarified subject and updated label
Best Answer10-17-2020 22:55
10-17-2020 22:55
I get the notifications but now i dont knowhow to turn them off on the inspire HR, any help would be great!
10-19-2020 18:14
10-19-2020 18:14
Hi @Odedsh. Welcome back to the forums.
Thanks for sharing that you have the Inspire HR and for your efforts while trying to remove these reminders. Just to confirm, are you able to see the Health & Wellness reminders option when going to the Fitbit app > profile picture > Inspire HR? May I know the model and OS/software version of your phone? If you've not done so, log out from your Fitbit account, check if the Fitbit app is updated, reboot your phone, log back in to your account and try turning off these reminders.
By the way, I've moved your post to the Inspire HR board so you can have more chances to receive help from the Community.
I look forward to your reply.
Best Answer10-19-2020 22:11
10-19-2020 22:11
Thanks for your help.
I have followed the above steps but it does not work. I do not see those options on my IOS. I have iPhone 8 IOS version 14.0.
These options show up on my android phone just not on mt IOS. I logged into my Android and removed the washing hands notifications and then logged back into my IOS. I am hoping it works - so far had no reminders! It appears that this Health Nad Wellness section is not on the IOS version of the app, the app needs an update.
10-26-2020 07:48
10-26-2020 07:48
Hi Lizzy-- I am seeing this same problem. I am currently on iOS 14.1, and I have the latest app downloaded. However, when I click on my picture, and I click on the Inspire HR, but there are no Health & Wellness reminders... The only things I see:
Can you help? I would like to remove the notification to wash my hands.
Thanks,
Jennifer
12-10-2020 11:10
12-10-2020 11:10
I am experiencing the same issue as Jengab BUT with my Android phone.
These reminders are appearing randomly on my Fitbit Charge 3, and I have zero way to remove them.
I can remember setting them up to happen. Now though when I go to remove them, there is no way to remove from from the Android app, iOS app, or when I am in my account on fitbit.com.
Please help!
Best Answer12-14-2020 07:16
12-14-2020 07:16
After speaking to support, I found the the option to turn off random notifications such as the water reminders is "not available" for the Inspire HR. The steps for turning off Health & Wellness notifications in the app do not apply, as the app does not show a "Health & Wellness" option after tapping the Inspire HR icon.
It appears that the water reminders function was implemented but without an "off" option. I would like to suggest that the option to turn off water reminders be made available for the Inspire HR.
12-14-2020 08:39
12-14-2020 08:39
01-11-2021 16:35
01-11-2021 16:35
This option doesn't show for versa 2 users either. I (regrettably now) bought my mom an inspire 2 that shows the option. The only thing fitbit is consistent with is being inconsistent.
Best Answer02-14-2021 06:57
02-14-2021 06:57
For me the Health & Wellness settings are under MobileTrack, not Inspire HR.
