02-10-2020
16:21
06:02
JuanJoFitbit
02-10-2020
16:21
06:02
JuanJoFitbit
trying to turn off auto sync. instructions followed to the point where it says find the spot to turn off auto sync. if I could find it, I would. but I can't find it!!! from account access, where is it?
02-10-2020 17:20
02-10-2020 17:20
If you mean 'All-Day Sync', from phone app Account page, tap your tracker, then scroll down to 'All-Day Sync'.
Best Answer02-13-2020 17:41
02-13-2020 17:41
02-13-2020 19:17
02-13-2020 19:17
When posters don't specify which app/sync device they are using, I generally assume phone app because that seems to be the most common, and if you don't tell me, my ESP is not very accurate. The alternatives are to first ask what app you are using and then wait to see if I get a response, which tends to annoy someone in a rush for an answer, or to give several answers to fit phone app, Windows 10 app, fitbit.com dashboard, and I'm not going to go to that much work when so often people don't even give any notice they have read my reply.
Best Answer10-04-2020 08:25
10-04-2020 08:25
I have no such option either. Charge 2 and using an android. Samsung 10e. No way to turn off all day sync.
10-04-2020 08:27
10-04-2020 08:27
I have a charge 2, use and android phone Samsung Galaxy 10e. No such option as all day sync. Any other suggestions I could try..
10-04-2020 09:00
10-04-2020 09:00
From Why was the all-day sync option removed from the Fitbit app?
To improve your experience with notifications, syncing, and firmware updates, we removed the option to turn off all-day sync from the Fitbit app. When your phone is near your Fitbit device with Bluetooth turned on, it periodically syncs with the Fitbit app to update your stats and download available firmware updates. More frequent syncing rarely, if ever, noticeably decreases your device’s battery life.
Best Answer01-24-2021 10:49
01-24-2021 10:49
This simply is not an option.
01-24-2021 10:50
01-24-2021 10:50
I find this comment to be condescending and very unhelpful.
07-04-2021 06:45
07-04-2021 06:45
It's ridiculous that the option was removed. Why not let each user decide? Also, when mot connected to the internet, synching will cause data usage.
Best Answer09-15-2021 10:57
09-15-2021 10:57
Turn off all notifications and sync manually. You won't get notifications on challenges until you sync, but who cares? It extended my battery charge quite a bit to do this.
