04-05-2019
16:11
11:58
AndreaFitbit
04-05-2019
16:11
11:58
AndreaFitbit
How do i turn off the fitbit inspire hr?
Best Answer08-05-2021 18:28
08-05-2021 18:28
Welcome to the Fitbit Community, @DANNNYBAMF.
Thank you for joining the thread and sharing your input. I would like to confirm that Inspire HR can't be turned off. For more information, see How do I turn off my Fitbit device? I was able to see that you have already contacted our Support team regarding this and that they were able to assist you. Thank you for your time and efforts.
See you around.
Best Answer04-05-2019 21:45
04-05-2019 21:45
Welcome to the forums!
May I ask why you want to turn it off?
Wendy | CA | Moto G6 Android
04-06-2019
04:36
04:21
JuanJoFitbit
04-06-2019
04:36
04:21
JuanJoFitbit
When i decide i want to take it off to sleep 1 night i like to turn it off.
How do i turn mine off?
Moderator edit: merged reply
05-22-2019 11:28 - edited 05-22-2019 11:30
Scroll to setting on the watch scroll down to About, tap it and scroll down to shut off
The manual is here as well
08-24-2019 12:26
08-24-2019 12:26
On my fitbit Inspire HR there is no 'About' under settings. There is 'Device Info', but there is no option to turn the device off.
Not sure why the information provided is incorrect, nor why it received a vote? Perhaps the menu options have been changed in a recent firmware update?
Also the provided user manual link doesn't mention anything about scrolling to About, tapping and scrolling to shut off either.
11-14-2019
09:58
05:01
JuanJoFitbit
11-14-2019
09:58
05:01
JuanJoFitbit
I have the same issue.
I also have no shut down options in the settings screen. I think I previously did, but haven't tried to shut down in awhile.
12-20-2019 09:09
12-20-2019 09:09
I also want to know. I can't wear this while I sleep. It keeps me up. But I don't want it recording those bogus 100+ heart rates and the green lite comes on. What about in the shower. I'm told it's not waterproof.
02-17-2020 04:43
02-17-2020 04:43
I wanted to shut it off to put on a screen saver because it is a wet install and the directions say to turn it off. I scrolled down, but the response given was not correct, there is no option to shut off under settings. I read through the manual and it does not address shutting down. I am currently wearing it until it runs out of battery power so that I can put on the screen saver, but there should be a way to shut it down. Is there?
Best Answer03-06-2020 09:10
03-06-2020 09:10
Facing the same issue.. not able to turn it off
Best Answer03-20-2020 18:11
03-20-2020 18:11
I looked in the manual that someone posted.. was for a different issue but in solving it, one needed to shut off the unit. You must put it on the charging cord and then hold that side button for ‘5’ seconds.. or so. Will shut off then and give you a smiley face...
worked for me!!
i was able to restart mine and it reset itself, fixing my issue
hope this helps
07-06-2020 15:12
07-06-2020 15:12
I tried connecting it to it's charger and pressing the button and saw the smiley face....still didn't shut down. No vibrating and turning off, just smiley face. I got a new Versa 2 and wanted to turn my old Inspire HR off. Any suggestions?
08-06-2020 09:50
08-06-2020 09:50
I had exactly the same experience.
Best Answer08-20-2020 06:07
08-20-2020 06:07
Same problem as everyone else. I got a charge 4 and need to turn off the hr to store for a backup. Nothing suggested here works and no mention of shutting it off in that manual. Seriously, shutting off a device shouldn't be impossible and certainly not so convoluted.
Best Answer08-20-2020 06:16
08-20-2020 06:16
Best Answer08-20-2020 07:34
08-20-2020 07:34
My Fitbit won’t sync
09-06-2020 00:00
09-06-2020 00:00
DID NOT WORK on Inspire HR!
12-04-2020
09:40
05:02
JuanJoFitbit
12-04-2020
09:40
05:02
JuanJoFitbit
There is no "About."
There is nothing in the manual about shutting down/turning off. Only instructions for erasing data or restarting.
Best Answer02-10-2021 09:54
02-10-2021 09:54
I think this does not apply to Inspire HR
Best Answer02-15-2021 10:57
02-15-2021 10:57
Worked for me. Thank you!
21:36
04:19
JuanJoFitbit
03-11-2021
21:36
04:19
JuanJoFitbit
this answer is WRONG! There is no "about" setting on an inspire......this info seems to be for a fitbit Sense, but WILL NOT work for an inspire. Does anyone have a correct answer? The community legend doesn't seem to know.....
I'm pretty sure that hitting it very hard with a hammer will work, but you won't be able to turn it on again.....
I just had an online conversation with a help desk person....the answer from them is that an Inspire cannot be turned off...you just have to wait until the battery dies......I replied I thought that was a dumb design...so I guess I;ll be letting my battery die. The so-called best answer should be removed, as it isn't best, or even correct...sorry WendyB, nothing personal, but your answer doesn't apply here....the best answer is that you CAN'T turn it off....
