How do I turn off the buzz when I reach a (step) goal?
It feels creepy and I want to stop it. Tried turning off Notifications, but that didn't work. How??
4 REPLIES 4
Hi @Maenad  if you mean the daily celebration upon meeting your goal, there is no way to remove it. Now, if you want, you can set the step goal higher than you know you'd reach and there would never be that buzz. Another way of doing it would be to make calories your main goal and not steps. Glad you're with us.
Stepping in the U.S.A. since September 2013. Android 14
I see. So my choice is meaningful goals or lack of creepiness. Yay.
@Maenad  any chance you'd get used to the celebration?
It really irritates me but I have a solution. If you go to settings- main goal and change it to something like calories- then go back to the today page and press the calorie count and go to the settings and change calories burned to a goal you know you will never get up to- and let it sync. That should stop it from happening
