10-04-2022
23:00
21:04
10-04-2022
23:00
21:04
How do I turn this off it’s sooo annoying
10-05-2022 05:10
10-05-2022 05:10
Hello @Ciaran537990999
Unfortunately there isn’t a way to stop this notification that’s usually referred to as a celebration notification when you reach your daily goal. But if you have your reminders to move enabled as well you will get even more vibrations. You can turn that off if you like.
Here’s how…open the Fitbit App, tap your profile picture then scroll down and tap inspire 2. Next scroll down to and tap reminders to move and disable them. Once you’ve made the change be sure you sync your Inspire 2 so that your tracker will accept any changes you may have made.
‘I’ve seen other users not particularly fond of the celebration (fireworks etc) as well and they decided to increase their daily step count into something they know they wouldn’t get per day so they never have to deal with the cheer notification they don’t want. That’s something you can consider as well but you won’t get your daily step streak if you do that so keep that in mind as well.
I hope this helps and answers your question. Please let me know
10-10-2022 16:12
10-10-2022 16:12
It's not just a daily step goal that sets these off. It's when you hit certain milestones or sustain a pulse rate for a certain amount of time, or something. They annoying because they are not spaced apart far enough. For instance, I just got back from a short and slow run and I swear, I was getting "cheered" on every 1-2 minutes. So much so that it was interfering with my checking time and distance.
10-11-2022
06:40
05:17
10-11-2022
06:40
05:17
Hello @Webtoe22 and welcome to the Community. I think you are describing the heart rate zone notifications. You can turn them off in the Settings app on the Inspire 2 itself. Swipe down on the clock face until you get to the Settings app. You will find it there among other available settings.
@Ciaran537990999 Fireworks are one of the daily goal celebrations and I've seen the disco ball, too. If your daily step goal is important to you (because you follow your Step Streak), then change your Main Goal to something else and set to to a higher number. You set your Main Goal by tapping on your profile avatar > Inspire 2 > Main Goal. I have Distance as my Main Goal (several miles more than I ever do in a day), and still get my Step Streak -- and no vibrations when I reach my step goal. Please check your heart zone notifications, too, if that is part of your issue.
Laurie | Maryland
