06-08-2022
21:24
22:22
06-08-2022
21:24
22:22
My fitbit inspire hr shows 4:22 how can i change it to 11:23 pm
06-13-2022 07:10 - edited 12-18-2023 09:21
Hi there, @Rikkibarrett. Welcome to the Community Forums.
As @Heather-S has mentioned, please keep in mind that your Fitbit device may show an incorrect time if it hasn't synced or has been unpaired from your Fitbit account. Your Fitbit grabs the time of the device you're syncing with. To make sure your watch has recently synced, go to your Fitbit account, tap the Today tab > your profile picture > your device image.
If by any chance you are running into syncing issues, see Why won't my Fitbit device sync? or if you need to relink your watch, see How do I set up my Fitbit device?
Also, note that the time on your Fitbit Inspire 2 may be wrong after you travel to a different time zone or when clocks change for Daylight Savings. If you changed time zones and the time on your Inspire is still incorrect after syncing, make sure the time zone setting is correct. For more information, see How do I change the time on my Fitbit device?
If none of the above works for your, I recommend changing your time zone to a complete different one, sync your device, put the correct time and sync again.
Hope this helps.
06-09-2022 05:59
06-09-2022 05:59
Hi @Rikkibarrett. Do you have it synced to your phone? If it isn't syncing to your Fitbit app, the clock can get off track.
Hope this helps.
