How do I wear my Fitbit Inspire?
Cannot connect to support ...the language tab stays only on Spanish and therefore I cannot send a message. I simply want to know the magical solution to putting on my inspire band....they should make a Velcro or some other easy method band....it is very frustrating.
1 REPLY 1
It's nice to see you back in the community @Williamtaylor! I'll be glad to assist you with your wearing your Fitbit Inspire band. Thank you for your velcro comment and I'm sorry it's very frustrating.
You can change the language at the bottom of the page:
To wear your Fitbit Inspire:
  1. Place Inspire around your wrist.
  2. Slide the end of the wristband with the peg through the loop.
  3. Align both ends of the wristband so they directly overlap, and choose the hole
    that best fits your wrist.
  4. Align both ends of the wristband so they directly overlap, and choose the hole that best fits your wrist.
    User-added image
    1. Squeeze the peg and wristband between your thumb and forefinger until you feel the band snap into place.
    User-added image
    User-added image
Please let me know if you need further assistance.
