07-11-2019 03:46
07-11-2019 03:46
Is there a way to turn off the Inspire HR watch internal Bluetooth? If not, I would love to see this added in a later update! Is it possible to put in a request for this added capability? I think this would give it an even better battery life as I only Sync with my phone at certain times (to save phone battery) and the watch seems to continuously keep its Bluetooth on. It would be a simple add to the Quick Settings screen below Notifications and just tap to turn on when I need it and tap again to turn off when I don't need it to save battery and reduce potential interference issues.
03-06-2020 11:48
03-06-2020 11:48
This is really too bad. It just tipped my buying decision to the Garmin Vivosmart 4, which does have the ability to disable bluetooth.
07-11-2019 04:44
07-11-2019 04:44
It's not possible to turn off bluetooth at the moment.
There is a feature suggestion for this which you might like to vote for. You can find it at https://community.fitbit.com/t5/Feature-Suggestions/Ability-to-disable-Bluetooth-in-restricted-areas...
Note, though, the comment from fitbit that they don't currently have any plans to implement this change.
07-18-2019 10:43
07-18-2019 10:43
Thanks for the quick reply. I have added my vote for this feature. With nearly 1000 votes and tons of comments do you know why Fitbit wouldn’t consider implementing this change in the next update?
07-18-2019 10:48
07-18-2019 10:48
I've no way of knowing fitbit's thoughts on this but they have no obligation to accept our feature suggestions. Perhaps they just don't want to.
03-06-2020 11:48
03-06-2020 11:48
