10-04-2020 23:36
10-04-2020 23:36
How can I add a different sport activity?
Best Answer10-05-2020 05:10
10-05-2020 05:10
Hi @Samb73 What sport do you want to add? Is it one of the exer ise shortcuts listed in the app? Go to the app, select you account (avatar/icon in top left corner) and select your Inspire HR. Scroll down to Exercise Shortcuts. (To see the whole list you may need to remove one from your tracker). If it not one on the list then you cant add it to your tracker, but you can manually start a 'Workout' activity and them change the name ofnit in your app afterwards.
Helen | Western Australia
