02-12-2021
17:08
04:21
JuanJoFitbit
02-12-2021
17:08
04:21
JuanJoFitbit
Can I increase the strength of the vibration?
02-13-2021 04:21
02-13-2021 04:21
Hi @JMCFEH, welcome to our Fitbit Community. Regarding your question about the vibration strength adjustment, please follow the steps listed in this help article, under the subject Inspire 2 > Adjust Settings > Vibrations, in order to adjust the strength of the vibration motor of your device.
Keep me posted on the outcome.
02-15-2021 23:53
02-15-2021 23:53
07-12-2021 15:46
07-12-2021 15:46
I am having the same problem
07-13-2021
02:08
13:12
SilviaFitbit
07-13-2021
02:08
13:12
SilviaFitbit
Hello,
Please follow this steps:
Moderator Edit: Word choice
07-20-2021 16:33
07-20-2021 16:33
Checking the site you referenced there is no accessibility option in the settings app for the inspire 2…
07-27-2021 07:33
07-27-2021 07:33
There is nothing in this article about Inspire 2.
07-30-2021 05:42
07-30-2021 05:42
There is no such setting as you describe. I am often directed to non-existent settings like this.
07-30-2021 13:02
07-30-2021 13:02
Not the right link. Nothing there about adjusting alarm. In fact does not even address Aspire 2, Got anything else?
07-31-2021 08:21
07-31-2021 08:21
"Please follow this steps:
There is no "Vibration & haptic strength" option on my Android Samsung S10e under Accessibility. Are your instructions for Apple products? There isn't an Accessibility option on the Inspire 2 account settings under App Settings.
Where do I find the options for your instructions?
08-27-2021 10:07
08-27-2021 10:07
There is also a Settings app on the device itself, which can be found by scrolling down (instead of up) from the home (clock) screen. Just keep scrolling past Notifications, Exercise, Relax, Timers, Alarms, Tile (if present) and tap on Settings.
On my Inspire 2, the Settings options are:
No "Accessibility", "Vibration & haptic strength" or anything like that.
01-25-2022 18:38
01-25-2022 18:38
@tonkscat you are asking about an Aspire 2? We are in community for Inspire 2. I agree there is nothing here matching current Inspire 2 settings app. The moderator might well move you over to the Aspire 2 feed @JuanJoFitbit My Fitbit Inspire 2 is Version 20001.124.28. It has neither an approach to this solution in the device settings app nor the Fitbit App on ios, android or Win 10.
