How to change sleep sensitiveness on Inspire
I think my sleep sensitivity settings are changed somehow and I can't find the option to reduce it to Normal. When I go to Account->Sleep the option for sleep sensitivity is NOT there. When I go to Advanced Settings, it is also not there. My Fitbit rapidly drains itself of battery every night right now and thinks that I'm awake up to two hours a night haha. Help!!!
Screenshot
1 REPLY 1
Hi @ashmo, welcome to the Community Forums! Sorry for the delay in responding your post.
Thanks for bringing this to our attention and for the details that were shared. Let me share with you that it's not possible to change the sleep sensitiveness on your Fitbit Inspire. However, if you're experiencing accuracy issues with the sleep information that's tracked, I suggest you to restart your Inspire and then try wearing your device on your non-dominant hand.
For the battery drain situation, please check: Can I extend my Fitbit device's battery life?
Keep me posted and let me know if you have any additional questions.
