08-24-2021
17:27
04:15
AlvaroFitbit
08-24-2021
17:27
04:15
AlvaroFitbit
My Inspire hr is showing the wrong time after charging. How do I set the time?
Best Answer08-24-2021 17:47
08-24-2021 17:47
It will get time from phone when it syncs. That is the only way to set time.
04:20
07:22
08-25-2021
04:20
07:22
@KarenBen I hope you're doing well!
As @JohnnyRow said once your tracker syncs the time should be updated but I wanted to add that you can select a different timezone if you need that too. You can check the instructions in this help article to do so.
Hope this helps.
