03-17-2020 17:20
03-17-2020 17:20
all of a sudden it went from correct time to 4 hrs latter
Best Answer03-18-2020 01:22
03-18-2020 01:22
You can't manually set the time but it should reset itself whenever it syncs to your phone or computer based on the time on that device. Does your fitbit seem to be syncing ok?
The other thing that affects the time is the timezone in your profile. You can check yours at https://www.fitbit.com/settings/profile If you do change it then you'll need to sync again to update your fitbit.
03-18-2020 01:22
