How to fix the glare on Inspire 2 screen?
Any way to fix the glare on the screen. If I am in the Sun, I can’t see the time, etc.
2 REPLIES 2
I understand that bright sun can definitely be a problem, @Warzone1. When I wear my Inspire 2, I find that cupping my hand over the screen helps quite a bit. If this is a newer problem, go into the Settings App 953988B7-C349-434E-BFD0-3B0BC602F9F0.jpegon your device and make sure the Dim Screen feature is off.
Tried that.  Sometimes that doesn’t even work.
