04-10-2019
18:03
06:49
AlvaroFitbit
04-10-2019
18:03
06:49
AlvaroFitbit
I’m having trouble receiving text messages on my Inspire. How do I set that up? I’m getting phone call notifications. I have an iPhone X.
01-01-2020 19:33
01-01-2020 19:33
Best Answer01-01-2020 19:35
01-01-2020 19:35
Call Fitbit support at +1-877-623-4997
Best Answer01-01-2020 19:43
01-01-2020 19:43
Best Answer01-08-2020 07:44
01-08-2020 07:44
I had the same issue until just now (and I bought it this morning). Nothing about navigating the settings>apps>notifications instructions worked for me, solely, until I played around with the app. From the dashboard "today" page in the app, select the "person" icon in the top left. Select your device under "Devices", then scroll down and select "Notifications". There, you can manipulate which notifications you receive and from where. Now, this worked for me after restarting the device a few times and making sure the notifications icon was not unselected on the device. So, it may have been a combination of these tactics or only one, I cannot say, however, it didn't start working until I went through the app. But now, it stays connected to Bluetooth.
Hope this helps.
Best Answer01-08-2020 10:59
01-08-2020 10:59
Best Answer01-28-2020 17:19
01-28-2020 17:19
My inspire HR was working well for text and call notifications until the very recent update. Im using huawei P30
Hope they find the bug immediately
Best Answer02-06-2020 09:10
02-29-2020 09:04
02-29-2020 09:04
I just tried this and it worked... never knew something so simple was the fix. I tried pairing and re pairing. But this fixed it. Thanks so much for sharing.
Best Answer03-01-2020 14:23
03-01-2020 14:23
Best Answer04-16-2020 21:06
04-16-2020 21:06
I literally just received my Fitbit today and already love it. I too was just receiving phone call notifications but I have figured out how to get text messages for iPhone. You cannot have your notifications “hidden” on your phone. So basically when your iPhone is locked and someone texts you it will show up on your lock screen or at least a part of the message. Once this is set it will show up on your Fitbit.
Best Answer04-28-2020 03:29
04-28-2020 03:29
Thank you so much for this. I followed every step and it worked.
Best Answer06-08-2020 18:52
06-08-2020 18:52
Hello
i just received the Inspire HR and text messages were not alerting on the FITBIT. After 2 frustrating hours, I solved the problem.
>SETTINGS. >NOTIFICATIONS. >SCROLL TO MESSAGES. MAKE SURE >SHOW PREVIEW IS ON >ALWAYS. Mine was on Never which was why I couldn’t get texts. Please include this tip in your troubleshooting guide. My Alta stopped receiving texts when I got the iPhone 11. Apparently the default is never and I never knew to make sure show previews was toggled on. Please share.
06-16-2020
10:15
05:50
06-16-2020
10:15
05:50
@Beck00 Welcome to the Community.
Thank you so much for sharing this tip with the Community. This is already stated in the help article: How do I get notifications from my phone on my Fitbit device? where it says:
Show previews
Tap Settings > Notifications. Make sure Show Previews is set to Always or When Unlocked.
Still thank you for helping others by sharing this information.
Let me know how it goes.
Best Answer07-13-2020 10:00
07-13-2020 10:00
I tried that too. Still not working. Ive tried EVERYTHING!
Best Answer07-13-2020 10:01
07-13-2020 10:01
Me too. Ive tried all of the instructions I can find on the internet for months. Still cant get it to work.
Best Answer07-13-2020 10:05
07-13-2020 10:05
Agreed.
Best Answer07-13-2020 18:07
07-13-2020 18:07
I had tried all those suggestions except plugging the watch directly to my laptop with its charger. So After several days of just leaving the watch alone I did plug it directly into my laptop and it turned on immediately. I couldn’t believe it. I was so happy because it was a gift from my son. Plugging directly into the laptop must have jumpstarted it.
Best Answer07-13-2020 19:21
07-13-2020 19:21
I have followed all the instructions and yet I still can't get the notifications to work.
Best Answer08-23-2020 22:05
08-23-2020 22:05
I have read the entire thread and done just about everything suggested and I still could not get text messages on my Inspire HR.
In checking Bluetooth settings finally, I noticed the Alta that I replaced with this new Inspire was still syncing with Fitbit even though I had removed it from the Fitbit iPhone app. I selected "Forget This Device" and rebooted the Fitbit app on the phone and instantly I began getting my text messages on my new Inspire HR.
I hope this may help some of you that still do not have your issue resolved.
ThaJeweler
Best Answer08-28-2020 10:07
08-28-2020 10:07
I found that I followed all the instructions and none of them sync'd, then if you go into APP permissions on your phone, you can change it there for allowing text, phone, ETC. Even if you think you are allowing it, or have it marked in the app or under notifications, it can still be denied in your app permissions.
