04-10-2019
18:03
06:49
AlvaroFitbit
04-10-2019
18:03
06:49
AlvaroFitbit
I’m having trouble receiving text messages on my Inspire. How do I set that up? I’m getting phone call notifications. I have an iPhone X.
10-03-2019 11:04
10-03-2019 11:04
any resolution to this? I have same issue.
Best Answer10-03-2019 12:45
10-03-2019 12:45
Best Answer11-14-2019 12:53
11-14-2019 12:53
How did you get yours to correct?? I have done all of these things and it is still not showing texts or calls
Best Answer11-14-2019 13:18 - edited 11-14-2019 13:19
Hi. I have a fitbit alta. I spoke to a customer service rep that sent me an article that helped. But they did say they are still fixing this bug on all operating systems.
Here are the steps that helped me (I had to dig through my app notifications to find where this was turned off on the fitbit app). Link to article - https://help.fitbit.com/articles/en_US/Help_article/1979#work
Go to "How do I setup Notifications" then select the type of phone. Follow all the steps.
Hopefully the link above has your answer just open the sections to find the steps to take.
Best Answer11-14-2019 13:33
11-14-2019 13:33
Best Answer11-14-2019 14:57
11-14-2019 14:57
Best Answer11-14-2019 18:02 - last edited on 03-04-2020 17:39 by LiliyaFitbit
Can’t tell you how many hours I spent trying to get notifications on my
Inspire. It works now, but online instructions seriously lacking.
Ruth
11-14-2019 18:38
11-14-2019 18:38
Best Answer11-14-2019 20:11
11-14-2019 20:11
I pressed and held the side button till the battery symbol came up, then scroll to the icon that looks like a document. Touch that icon till it’s “whole”—no jagged line across it.
Best Answer11-15-2019 04:02
11-15-2019 04:02
Best Answer11-15-2019 04:58
11-15-2019 04:58
Best Answer11-18-2019 19:13
11-18-2019 19:13
How did you fix it because mine is not working either
Best Answer11-19-2019 04:47
11-19-2019 04:47
I followed whatever instructions there were online to get my iPhone paired with the Fitbit, which still didn't work, but may have paved the way. Then I pushed the side button on the Inspire and held it until the battery showed up. Then scrolled down till there was a "document" icon on the screen. It was split in two. When I touched it, it became solid, and I could receive notifications. NOWHERE in the Fitbit website did I see anything about this, and it's an awful omission. I spent HOURS trying to fix this. Hope you're successful.
11-19-2019 06:01
11-19-2019 06:01
Best Answer11-19-2019 06:03 - last edited on 03-04-2020 17:39 by LiliyaFitbit
Right last I knew it was because of the update on iPhone but there has been two releases since I got my Fitbit and it’s not working
Best Answer11-23-2019 14:56 - last edited on 03-04-2020 17:39 by LiliyaFitbit
I think you should. This problem should be addressed in their
troubleshooting.
Ruth
Best Answer11-24-2019 17:20
11-24-2019 17:20
Best Answer12-26-2019 07:30
12-26-2019 07:30
some iPhone are have trouble because of the software update. so try changing your software update. If it does not still work call fitbit support .they are very nice. don't press any numbers when you call let them, pick up. they are very kind and they are helpful. their number is 1 (877) 623-4997.
Best Answer12-30-2019 16:49
12-30-2019 16:49
Changing the preview feature in messages under notifications to ALWAYS worked for me too but I don’t want a preview of my full text messages to appear on my phone. So it seems that I have to choose between getting text notifications on my Fitbit and having my texts show in the preview screen on my phone.... or switch back to no text preview on my phone and not get any notifications on my Fitbit. This doesn’t seem right and is very frustrating!!
Best Answer01-01-2020 15:47
01-01-2020 15:47
Can you help me get notifications and text messages on my Inspire and I have an IPod touch
