09-26-2022 19:39 - edited 09-26-2022 19:52
I got my Inspire HR in July 2021. I've worn it most every day since then. Last week, it literally fell off my wrist - the plastic around the little hook on the bracelet part, just broke completely off. I have tape on it to hold it together so that I can wear it, but this is absurd to have this happen in such a short time. I wore Fitbit Ones for YEARS with no damage at all. How do I get a replacement?
09-26-2022 20:48
09-27-2022 10:16
09-27-2022 10:16
I thought I saw two years. So ONE year and that is all you get out of a hundred dollar device? **ahem**. I won't be replacing it then.
09-27-2022 12:23
09-27-2022 12:23
@Chess unless you purchased an extended warranty, it's one year in the USA. You can always get with customer support to see if there are any options available to you.
09-27-2022 18:52
09-27-2022 18:52
@Odyssey13 , Nice to see you around. Thank you for the info shared.
@Chess A warm welcome to the Community Thank you for your message.
As recommended by Odyssey13 , the best place to verify your warranty status is with Support.
Even if the warranty should be over, give it a try, to see what they can do for you.
Here you'll find our contact options.
See you around.
10-10-2022 21:33
10-10-2022 21:33
Well the response from support was abysmal. They offered me a 35% discount coupon, but since the Inspire HR has been discontinued, I CAN'T EVEN USE THE DANG COUPON. And the new version (which obviously they made to replace the defective design of the Inspire 2/HR) is not eligible for the coupon. Thanks a LOT FITBIT! 😡
