05-22-2021 01:28
05-22-2021 01:28
Dear Fitbit community members,
I have a fitbit inspire hr watch and I have turned off stay awake option in it. When I want to see the time now I have two options either press on the button of the watch or press on the touch screen. Regarding the second option, I noticed that I have to press on the screen multiple times in order for it to light up and show me the time. Is this a problem in my watch or there is something I should do to make the screen light such as long press on the screen or double click on it for example?
Best Answer05-22-2021 20:28
05-22-2021 20:28
I found the option called "double tap" and it is activated on my watch, but for some reason I usually need to triple tap the screen in order to illuminate. Is this normal?
Best Answer05-22-2021 20:12
05-22-2021 20:12
I might not be remembering the right tracker model, but check in Settings; I think thee is an option to turn 'Double Tap" on or off. If I am right, make sure that is turned on and double tap screen.
05-22-2021 20:28
Best Answer05-22-2021 20:30
05-22-2021 20:30
Sometimes it illuminate when I double tap the screen and sometimes it illuminate when I triple tap the screen and sometimes it doesn't illuminate at all
