07-31-2019
15:37
07:47
AlvaroFitbit
07-31-2019
15:37
07:47
AlvaroFitbit
I have been trying to get a map to show up on my walks and johs. I have it on on my fit bit and GPS on on my phone via Google maps and also have tried map my run, nothing shows on my fit bit. How do I make this work?
08-01-2019
08:11
10:42
08-01-2019
08:11
10:42
@Sprather88, hope you are doing fine.
Thank you for your inquiry about tracking a GPS map with your device. This feature is called connected GPs and it uses your phone's GPS chip to track the map. Please follow these instructions to use the feature.
Let me know how it goes.
06-04-2020 06:07
06-04-2020 06:07
@AlvaroFitbit , you explained that it uses your phone's GPS, but then you provided a link to instructions on how to use the Fitbits that have GPS built-in. Not very useful at all.
06-04-2020
07:16
10:42
06-04-2020
07:16
10:42
@bekbek Thanks for stopping by!
Please check the article as it contains instructions for both devices with built in GPS and then ones that uses the phone's GPS chip.
I'll be around.
