07-05-2021
12:27
23:01
07-05-2021
12:27
23:01
When I click on alarms on my fit bit it tells me to add Alarms in the Fitbit app but it says that it is already downloaded
07-06-2021 11:23
07-06-2021 11:23
@Indy_welch Welcome to the Fitbit Community. Thanks for the details mentioned.
For Inspire 2, you need to set up the alarms on the Fitbit app and once they are set, you can view them on the tracker:
Learn more about it here How do I manage alarms on my Fitbit device?
Hope this helps.
09-16-2022 09:08
09-16-2022 09:08
Alarms does not show up on the app for inspire 2. What can I do?
09-17-2022 05:18
09-17-2022 05:18
Hello @Tashabird and welcome to the Community. I apologize if I'm misreading what you wrote. When you are looking on your mobile app, you tap on your profile avatar, then your Inspire 2 tile. The Silent Alarms setting is just below the Wrist setting, in the area that includes Notifications and Reminders to Move. If this doesn't help you, can you ask your question a different way?
The Alarms app is preloaded onto the Inspire 2. You can't uninstall it.
Laurie | Maryland
