How to set an Alarm on Inspire?
Please help me how to set an alarm on fitbit inspire i can't set it properly please help me.
6 REPLIES 6
  • iPhones, iPads, and Android phones
    1. Tap the Today tab
      > your profile picture > your device image.
    2. Tap Silent Alarms > Set a New Alarm.
    3. Set the alarm time and frequency, and save.
  • Windows 10 devices
    1. From the Fitbit app dashboard, tap or click the + icon >  Set Alarm > + icon.
    2. Set the alarm time and frequency, and save.
  • fitbit.com dashboard
    1. From the fitbit.com dashboard, click the gear icon
    2. Under Silent Alarms, click Add New Alarm.
    3. Set the alarm time and frequency. Be sure to enter the alarm time in the format HH:MM.
    4. Click Save. If the entry box turns red, you may have entered your alarm time in an incorrect format. Be sure you include a colon between hours and minutes.
    5. Click the Fitbit Connect icon
       > Sync Now.
Unable to connect to Inspire  please help me how i can fix it
If you get syncing / connection problems then the things to try are:
please help me how to uninstall an alarms on inspire i-can't use it please help
Hi @danilotrillo37  I moved your post over here. @JohnnyRow  answered it in the second post in this thread. What's going on?
Stepping in the U.S.A. since September 2013. Android 14
all you need to do there should be a cancle button so just click that
